I would like to use your Header Template 51 Overlay menu, but it doesn’t work. I don’t know why. I try to use Header Tamplate 51 menu, and it is OK, but also i would like to have Overlay menu on some of my pages. Can you help me with that.
thx
If the problem appear when you are trying to import the header template overlay 51, there is a problem with some header templates, this is one of them, we try to fix this problem as soon as possible, sorry for the inconvenience!
