Problem with "Page template setting"
Hi, I have a problem with displaying template settings when editing a page.
Before I could see “page template setting”, not now.
The blue tick is selected in the settings: https://imgur.com/a/fd2NL5r
Thank you
This is an issue, until this is solved, you can use the classic editor.
Perfect, with the classic editor it works, thanks!
How did you se the classic editor? By installing the related plugin?
Thanks,
Max
Hello @Maxyct,
Yes, you need to install the plugin.
