A new issue has appear in my site, although I have been using the newspaper theme for 8 months.
The site is http://www.lifeder.com/
If you go to page 2 (www.lifeder.com/page/2/ ) it is going to an article.
How can I solve this?
thanks.
Hello albrub,
Please make sure you have the ultimate version of the theme (6.6.2). The last update was released on 15 December 2015. Try to download from ThemeForest the ultimate version and install it correctly. After these changes if your problem is still there, please try to disable all the active plugins, except Visual Composer, clear all your caches, purge the CDN file if you use it and try it again. I’ve checked your website and your Console and I saw you have some js. errors, like this: http://screencast.com/t/tsheTJ9X I suppose it might be conflicting plugin.
Thank you for the message!
Hello Bluehacks,
Please ensure that you have the latest version of the Theme (6.6.3) and this was released on 23 December 2015. This kind of issues were caused from WordPress 4.4 and not from Yoast Plugin. After you have updated your theme, please try to disable all the active plugins, except Visual Composer and SEO Yoast (tested plugin), clear all your caches and install only the plugins that come bundled with our theme and try it again. It is necessary to do this because in that way you can rule out the plugins in conflict which can cause some errors in theme.
