Problem with pagination front-end
We have a problem with pagination. It looks very strange on a post page. Please help us to fix it.
Page example: http://metronews.net.ua/news/kubiv-prizyvaet-narodnyh-deputatov-podderzhat-zakonoproekty-po-besplatnomu-obespecheniyu-uchebnikami/
Do you have any custom modification to the pagination? If not please check this also without any plugins active, leave just Visual Composer active, clear cache and purge your file if you use CDN, then see if you still have this issue.
Hello.
I’ve done it, but pagination is still shows not correct.
Maybe U can use Ajax, not classic pagination?
Thanks, but we need to use classic pagination
I see that you have modified the style.css file manually and have strange characters. http://screencast.com/t/r7YS79v0bzJ
please remove the custom css from there and add it in Theme Panel -> Custom CSS section, without all those text comments. http://screencast.com/t/PBFVIhRB8 and see if works.
Hi! I try it, but it still not works.
You have solved the issue? I see the page 2 works now http://screencast.com/t/dmi1sboo6L
Yes, I’ve solved it.
