I’ve had a hard time documenting this issue and I hope you can (and should) help me fix it.
It all starts from the new update from version 12.4 to 12.5 in Newspaper.
The problem appears in the “Flex Block” module when using “Pagination” (whatever the selection) and trying to filter by “Post Type:” with the “Category filter:” option with the “Single – Related from taxonomy” option ” and a specific taxonomy to be displayed within the content type is added in the “Single – Related from taxonomies:” box.
First I leave you the video so you can see how it works correctly in version 12.4 and it was running correctly before the update to 12.5. Let’s go there! (please note the time and day below to see that it is only the update that matters). We will do everything on the same post so that there are no doubts https://www.trebol-apuestas.com/tragaperras/ancient-script/
Watch video — https://www.loom.com/share/88f2105a9de84a94a26f73fb53d06b27?sid=1ecaa2b1-df53-46eb-b8c6-5cb36729a8ec
Not all right! Games that are organized by CPT UI and that in turn penetrates ACF with the personal field “study”.
Now we are going to version 12.5 and for this we will see how it works first and then I will show it in depth with another video. (Remember we’re only 5 minutes after the previous video and having installed 12.5, all with the TAG DIV compositor the same!)
Watch video — https://www.loom.com/share/4a4c4cb1cf8349f28f8db52785b050aa?sid=bbbd3b21-b633-4668-a5d8-64b1b8b9eded
See, it already does what it wants, and it doesn’t filter by CPT UI with ACF once the scroll button is clicked as before.
Now, so that there is no doubt that it is not working, I am going to demonstrate it with the composer creating the 3 modules in this version 12.5 so that it can be seen that it REALLY UNDERSTANDS what it has to show but that it does not know how to do it when it is displayed, click next, show more and infinite load. As you will see in the video there are 16 games (slots) related to that CPT UI and ACF in this particular post, because when any type of pagination is added it stops working in version 12.5 (because I remember, in version 12.4 if it worked).
Let’s go there!
Watch video — https://www.loom.com/share/2d6a6469dc79491abde57d70f72b0c66?sid=5762832b-a76d-496d-ba4b-e89a1f756118
Let me know your solution!
Remember you can see everything in the post https://www.trebol-apuestas.com/tragaperras/ancient-script/ so that it does not affect SEO I have to put the other slots with only one module so you can review the problem in that entry.
