Problem with pagination
Hi!
Perhaps the answer to a similar question you have. Can’t find it.
Why two articles go to the next page?
First Page:
Second Page:
The problem originates from the number of posts you set to your block. It uses 3 columns so if 10 posts are set, it cannot align the 10 posts on a 3 column layout. 9 would be the best choice here. 10 or 11 will create a blank spot. It needs a x3 multiplier (3/6/9/12…etc) to display posts in every spot.
In any other column layout you would have this problem either it’s a 2 column or 3 column, if you do not set a post number according to the layout.
(The second page happens to have left exactly the number of posts required to fill the columns.)
You can edit a block to set the number of posts from block settings: http://screencast.com/t/7IQuNK1vi
You can also limit the latest articles on the homepage: http://screencast.com/t/uJc05fnQ5cp
I hope this helps
