I just installed the newspaper theme at http://atpatras.com and I have 2 problem
1) some of the images are not appeared.
And 2) some links goes to pages with the radio player I have installed before the theme.
I love this theme and I want to fix theese problems.
Hello kskpatra,
I have checked your website and I saw that most images are displayed fine, like this -> http://screencast.com/t/hnZo8c2KwWz and with your second problem, it seems to be an issue with your post link which might appear from your untested plugins. I have checked your console and I also saw that you have a lot of js errors and warnings through it. Please try to disable all the active plugins, leave just Visual Composer to active and install only the plugins that come bundled with our theme and rule out the conflicting plugins. Please clear all your caches and check again the results.
Hello kskpatra,
Unfortunately, this type of plugin are not tested with our theme and seems to cause a lot of unknown issues in theme. Unfortunately, we do not have any recommendation in this case because we have not tested these types of plugins, sorry! You will have to find another plugin with this functionality and see how it works on your side until you find the right one.
