Problem with picture/text overlay on: Category templates > Module 17
We imported the “recipes” demo, and started customizing it around a bit… However the category template/module isn’t displaying properly. The screenshot is below:
http://919dv.us/_private/newspaper-display-problem.jpg
It should be displaying as:
https://demo.tagdiv.com/newspaper/category/module-17-layout/
Right now the category is being displayed on our site right underneath the author name and date, when instead it should be all the way on the top left corner. This issue is only happening on desktop/regular views.
In smaller screens/mobile, it is displaying properly though…
Is there anyway on desktop/regular view to hide the category or to adjust it to display properly.. ?
