Problem with Popular 7 days posts
This feature of your beautifull template, is not working for me. I follow the distructions but i cant fix it. I dont use any cashe plugin on my site, exept your Speed Booster plugin.
Can you help me please ?
Here is 3 screenshots.
Image 1
Image 2
Image 3
Please make sure you also have the post views active and also test this without using caches as the last days 7 post count works based on post views so if you use cache this might not work properly.
Please also note that it pulls from ALL the posts the most accessed in the last 7 days NOT the posts that are published in the last 7 days.
Thanks for your quick response.
is it possible if i activate the post views to hide them with CSS, because i dont want to appear in my website.
thanks
Yes, you can use this custom css in Theme Panel > Custom Css: http://screencast.com/t/ZsV3wzHbj
.td-post-views {
display: none;
You are the best!
