Problem with posts and blocks
Hi guys, your theme is awsome but I m issuing problems with setting it up.
I want on home page to have tabs monday tuesday wednesday thursday friday saturday and sunday and that every shows up boxes with picture as it is here http://www.gdeizaci.com/en
I do not need it contected to calendar just tabs named by days you can see it here on the link
http://s32.postimg.org/wmcxqu02d/Untitled333.png
Can you please explain me what is what it is urgent to make it like that for my client.
i need it like this
now I have dropdown menu but I want it side by side day by day
Thank you for your generous thoughts and your review! We’re glad you like our theme. We invest a great amount of time and effort to create and permanently develop and improve our themes. This is why we truly appreciate your feedback.
You can use tabs element from, Visual Composer like here: http://screencast.com/t/4ZFDHUTv – http://screencast.com/t/q7hn8eShz7M – http://screencast.com/t/iMp2OEtAk1A
Hope this helps.
Hi is it possbile to make it like on the picture above?
Aaaa sooo easyyyyyy and I lost days trying to find it!
Is it possible to conect tabs directly to some calendar to change days by itself?
The theme does not have a calendar widget which change the day automatically but you can try to use plugin with a similar functionality. We can’t make any recommendation in this regard as we didn’t tested any plugins but you can do a search online and look for best plugins with this feature. Here you can find some informations which may help you in this regard: http://www.wpbeginner.com/plugins/which-is-the-best-wordpress-calendar-plugin/
