Problem with pre-loading
Dear Support,
on our pages we use the WolrdNews Plugin/Theme. But there is a problem with the pre-loading of other content then the displayed (see link to Screenshot). In the MainMenu on top as well as when you click on categories at one of the blocks. Everything is already set on “not preloading”, so where is the error or what can I do?
Thanks. Eric (konterrevolution.at)Screenshot pre-loading error
Screenshot
Did you set any redirect for main site url? From page source seems that the original url is this one: http://screencast.com/t/UUqJx6CqD4 When the theme makes the ajax calls there need to be present the original url, not a redirected url. As can be seen from this screen: http://screencast.com/t/a0GJAKRDsS2V the requested address and the address who makes the requests are different.
Try to deactivate all plugins except Visual Composer, clear all caches, purge the cdn if you’re using and also remove any redirects if you have any then test the site again.
