Problem with prev-next button
There is a problem on my homepage that you can see the link below.
http://i.hizliresim.com/a5l7L7.jpg
Or you can check it on my site: http://www.sosyalme.com
How can I fix the problem,
Thanks,
Ufuk
I have checked your site but you have only 4 articles on your Big Slide so the arrows don’t appear. I see that other theme icons are loaded fine, so please make sure that you clear cache and check this after.
