I just bought the Newspaper 9 theme and am using the Newspaper X template but when I want to preview my work which am drafting i get this problem of the preview not fully showing up instead it shrinks ,check link https://phonearenaug.com/?p=10037&preview=true.
Please de-activate the schema articles from here: https://www.screencast.com/t/0E3IucACC You will have to check that in order to deactivate the schema, this issue will be fixed in the next update.
Thank you for your understanding !
Same problem exists. “ENABLE ARTICLE SCHEMA” – disabled. Newspaper version: 12.3
Example
After Save and Publish – All ok.
Hi emerzlyakov,
Unfortunately, the screenshot you provided is no longer available.
Normally, the above problem should be resolved, I made some tests and for me, everything seems to be ok.
Do you have the last theme version? Also, if you are using a child theme, please check it with the main theme.
I’m sorry for the bad link, here are the correct ones:
Preview before Publish: https://app.screencast.com/UVbilaAF8kbdr
and after Publish: https://app.screencast.com/vLDi33QEQEqc6
Theme settings: https://app.screencast.com/eEzop1m9RP8R4
This reply was modified 3 years by
emerzlyakov.
I just did a new test and for me, the article in the preview appears ok. Maybe there is something extra involved.
If you are willing, we can investigate the problem and try to solve it as soon as possible, for this please contact us by email at contact@tagdiv.com and provide a temporary wp-admin and cPanel access.
