Problem with rendering some images
Some images are not displayed. When reloading the page they are displayed randomly. The images that do not display change and are not always the same. Could it be a javascript problem?
https://drive.google.com/file/d/1nnJEigSj672zugLVtruZICc-N2jT9Q1X/view?usp=drive_link
  • This topic was modified 1 year by maarlok.
Please provide the link to your website. Yes, there can be an issue with the optimization plugin.
Do you also want access to the back office?
Please do a test using the main theme, and please disable the WP Bakery plugin, clear the cache, and check if the issue persists.
With the default theme and Backery disabled, images load correctly.
You need to use the main Newspaper, not a default theme, because I saw that you have a child theme there.
I have deactivated WP Backery. I have used the Block1, Block2 feature to display posts and everything seems to work fine. Can Wp Backery be uninstalled?
This depends on you, whether you have used it or not. If you deactivated it and no shortcodes or issues appeared on the site, then you can delete it. What I can recommend is not using WP Bakery anymore, and instead, I recommend using Flex Blocks, instead of the 1 to 25 blocks, as they are much more flexible and offer more options.
Grazie e buona giornata!
