problem with responsive theme on smartphone
I have a problem with the theme responsive smartphone.
when I connect to my site from the smartphone with a screen
the written :
“Oops … Error 404
sorry, but tha page you are looking for does not exist.
you can go to the homepage ”
how do I fix?
my site: http://www.occhiodifalco.net
Hello occhiodifalco,
I have checked your website and I did not saw any problems in this regard. If you problem reappears I suspect this issue comes from your permalinks. So, you will have to re-save them from your panel, like this -> http://screencast.com/t/JyQ3kvVxNe and the problem should disappear.
Hope this helps!
