Problem with responsiveness of visual composer
Hello, i’m creating a page with content for mobile and desktop in the same page and i want to hide one to mobile and another for desktop but this doesn’t work… All content is visible for all devices and in normal mode i’m seeing the command offset=”vc_hidden-lg vc_hidden-md vc_hidden-sm vc_hidden-xs” is ok however in desktop or mobile i’m not able to fix this. Please check this page and tell me why your theme is not able to hide that to that devices
Hello vargaspazdaniel,
Please provide your website (the exact URL) so I can identify the problem. Notice that our theme is fully responsive and should works as expected. You can provide some useful screenshots to identify the problem.
This is the url: http://weekenjoy.com/guia-de-empresas/
Now you won’t be able to see the issue because i delete all the VC code and i put the widget with the theme options, however if i use VC code and use widgetized elements all the VC code i want to hide is always the same and this doesn’t work.
I recommend you to recreate all the pages which were made via Visual Composer to TD Composer if you want to achieve best theme results. Please check here -> https://forum.tagdiv.com/visual-composer-tagdiv-composer-transition/
With TD Composer i can’t hide rows to devices, with Visual Composer i can. I can’t use TD Composer….
Please check more deeply all the options from our TD Composer. Check here -> https://www.screencast.com/t/jPuhOD81C This functionality has been tested and should works as expected.
