Problem with Revolution Slider and Mobile Menu
I noticed a problem with the Revolution Slider when I use the mobile menu, and I found the same problem on the Animals Demo. This is what I did when I found the problem:
1. Open the mobile menu
2. Click on one of the social icons
3. Go back to the main site and close the mobile menu
What I then see with the Revolution Slider is this:
Is there any way to fix this? Does the parallax when opening the mobile menu have anything to do with this problem? If so, could I turn that off?
I’ve checked this on my side and didn’t got any issues with mobile menu or with the slider after clicking one of social icons. I am not sure why this happens on your site but you can try to clear mobile device cache memory then test again, also make sure that you’re using one of the browsers included on this list: http://screencast.com/t/Qqy5tnbf
