I want to use the Royal Slider Plugin for the gallerys. But there is one problem…if you click on the arrows at the right site of the gallery to maximize the size, you’ll see that the menü is overlapping the gallery.
http://dev.promicabana.de/das-ist-eine-testgalerie/
I don’t know if this a problem of the theme or the plugin.
Did you solved the issue? I have checked your site and I can’t find any issues with menu and slider.
