Problem with saving changes
I am unable to change ad sizes for a different devices in the theme panel. When I save it, changes will not take effect. What’s the problem?
Thanks for a quick response.
Do you use adsense code? Please note that the theme ad system was designed to work with adsense code and the theme will make it responsive and the ad will fill the available space. For non-adsense banners you need to add a specific size for each device as the theme will not handle it, please check documentation – https://forum.tagdiv.com/header-ad/
Please provide more details and you site url so we can take a look!
