Problem with saving settings
Hello, I bought your theme, and I started to configure it but I have a problem to save the settings.
The checkbox seems to work and that it saves, but when I refresh the page and go to settings again, nothing is saved.
Any ideas on this one?
If your panel settings are not saved, please check the max_input_vars value in system status section: http://screencast.com/t/V8MumQISR and make sure that it’s set above 2000. Contact your host provider and let him know about this if you can’t access php.ini file.
