Problem with search engine
Good evening, I wanted to know if someone else happens the same with the search engine on the subject. Resolved that when I put any word to search, the suggested results prior to the search page have nothing to do with the result it shows afterwards. The previous results are wrong but the end is correct, how can this be solved?
I also have a problem that is when characters are introduced as rare or the letter ñ for Spanish language gives a server error.
A greeting.
Solved!
