Problem with search. Help!
Hi!
when i try to search something like MOSTAR PRIJE; here is a example http://crnjaci.com/?s=mostar+prije, I get the results of my homepage (NASLOVNICA) and its codes, how i can repair that? it’s look terrible
Seems to be working now.
Also did search for MX4 and got the one result.
You can set layout for search results page in the theme settings panel.
sorry Chris S. can you look my eighth post in this link http://crnjaci.com/?s=mostar+prije, maybe i wasn’t clear enough first time 🙂 thanks
Weird. WordPress search shouldnt show stuff from home page.
Wordpress has kind of crappy search results, and there some plugins to help with that you might look at.
Add this function to your theme functions file: http://screencast.com/t/XB2LpOjyfR6
function SearchFilter($query) {
if ($query->is_search) {
$query->set('post_type', 'post');
return $query;
add_filter('pre_get_posts','SearchFilter');
  • This reply was modified 11 years by Lucian.
I did as you said, but now it does not work search in the media library :/
can you help? thanks
Use it like this:
    if ($query->is_search && ! is_admin()) {
    return $query;
.. or just add the && ! is_admin() part to the condition.
i will try and I’ll contact you later. thanks
