SInce I upgraded the site to the latest version of Newspaper I have an issue with the search – when I place a single word in search it is OK but when two or more are placed, the search combines it into a single word and results nothing.
Example: http://www.defense-update.com/?s=F-35
http://www.defense-update.com/?s=F-35&wings results in: http://www.defense-update.com/?s=F-35wings
I think the problem is with wordpress rather than theme, as I encountered this also with default themes, any idea how to solve this problem?
Please make sure that you deactivate all plugins, empty cache then check again maybe it’s caused by a plugin conflict. Also please update the theme if you are not using latest theme 4.6.1.
I also tested this and found no issues.
Thank you Alin,
I checked all plugins and found the cause, it was a redirect plugin that somehow wasn’t up to the recent wp upgrade.
