Problem with Share Buttons
Hay My share buttons look like below. How can I fix it.
https://www.dropbox.com/s/xw3or8nvdjo7y9o/aa.jpg
Please make sure you have replaced all files via FTP when you have done the update. Also clear all cache, browser cache, your site cache if you use a cache plugin.
I deleted all the files from server and then re upload the 3.5 update but no luck. I cleared all the cache.
Link to website : TuteCentral.com
Do I need to update td-social-counter and td-speed-booster plugins.
Yes website is fine.. Please check a post share options.. below the tags.. Then you will find the problem
Link : Link to a Post
Do you use W3 total cache plugin? Please disable the minify and use it only with Page cache enable. You have some JavaScript conflicts in console. http://screencast.com/t/jIZVwvw6z9
Thank you.. I solved the issue.. after disabling the minifying I need to clear the purge cache from cloudflare settings. Now its working perfectly. But still I findings error Uncaught ReferenceError: jQuery is not defined error in console..
Thank you Again 😀
