Problem with Sidebar
I want to be all sidebars 25% width. I understand that I can set up a row in TD-Composer with these values.
Is there also a general setting, where I can set this?
My problem is that I use this Plugin: https://demo.directoriespro.com/
It creates for special categories a page and also for its directories pages. The sidebars there then have a 33% width.
https://ibiza.abholte-media.com/directory-straende/
https://ibiza.abholte-media.com/directory-firmen/categories/hotels/
I talked to the support of that plugin and they suggested to ask you for Help.
How can I give you login credentials, so that you can see it?
Bernd Kühl
Unfortunately, no, there is no general option for this, what you can do is to use a pro demo or cloud templates from tagDiv Cloud Library, these can be edited with tagDiv Composer and you need to edit only the templates and will be apply on all posts/categories … that have set these cloud templates.
Our sidebars have 33.3% width by default -> if you want to chnage it, you need to edit theme with tagDiv Composer like this:
-> https://i.imgur.com/ptd3SNn.jpg -> https://i.imgur.com/PRkB7tQ.png -> https://i.imgur.com/dAgwoyv.png -> https://i.imgur.com/Z4OahyQ.png
Also if you want us to take a look to this conflict, you can send us an email at contact@tagdiv.com and provide admin login, as well as cPanel. We will take a look, but we do not garanty that we can fix it, because this is an untested plugin. Include a link to this topic in the email.
