Problem with sidebar and footer since update newspaper
After an update im starting having problem on theme
Hi when I’m editing a post with tagdiv i see the correct sidebar from the imported template
but on the website it don’t show off!
example https://co.auto123.com/ford-bronco-una-investigacion-de-un-problema-de-motor-catastrofico/ post its 100% width and also footer is vertical and ugly someone know how to fix that
Thanks you
Please make sure you do not have WP Bakery installed and active, clear the cache and try again.
Let me know the results!
Thank you its now fixed!
