I installed your theme and installed the Gadgets (normal one, not PRO) demo through WP Dashboard > Newspaper > Install demos. Now I want to activate the Infinite Loading for Single Posts (https://tagdiv.com/infinite-loading-for-single-posts/) but I didn’t have any items in WP Dashboard > Cloud Templates, so I imported Single Post Template 4 which is the template that resembles the most in the Gadgets Demo and activated the Infinite Loading.
The problem comes because the sidebar that shows widgets (Social Media, Most and Lastest Posts, etc) disappears in the imported template.
Can you help me showing how to activate the sidebar in the imported template? or to activate the Infinite Loading for Single Posts in the Gadgets demo?
Pics
– Post with the imported template (no sidebar):
https://imagizer.imageshack.com/img922/5240/oZTMSL.png
– Post with the default template form the Gadgets demo (sidebar)
https://imagizer.imageshack.com/img923/2656/O3K837.png
Pleas note that Infinite Loading can be enable only on single post template from tagDiv Cloud Library also these kind of templates can be editable only with tagDiv Composer, in your case you want to set the widgets for this you need to edit the cloud template and add the widget sidebar element and select the sidebar you want to display on the post that has apply this cloud template. -> https://imgur.com/kdF2np
