Hi, i’m having a little problem with single post template 39 from Cloud Templates.
Here’s the issue: in mobile/tablet view the post content is aligned on left and half of the page is blank.
Screenshot from your Live Preview: https://i.imgur.com/GtGxCsm.jpg
How can i fix it and show the content on full width page?
Regards
The screenshot i provides come from your live demo of single post template 39. You just need to open the preview from cloud templates.
https://cloud.tagdiv.com/forza-horizon-4/
Sorry, there is a mistake, was set a width on the template, we’ll fix it as sun as possible.
In order to fix this problem please click to edit the template with TD Composer, select the column , change to portrait view section css https://www.screencast.com/t/iqcSCjcR and remove the 38% width, and all will look good again.
Sorry for the inconvenience.
