Problem with singlepost template
i have setup my singlepost template but the “By Author” part has no space between By and the Author name.
I have added a space after By in TagDiv composer, but it has not come out on the live site?
  • This topic was modified 6 years by chicky365.
Hello !
Please provide a link to your website in order to inspect and provide a solution.
Hello !
That can be adjusted using the tagDiv Composer as you can see it here: https://www.screencast.com/t/p9IHaLHpdzJ
I have tried adjusting it via that way but I am unable to insert a space..
Hi chicky365,
From what I can see you do not set the space how Vlad S suggest -> https://i.imgur.com/t4btb9M.png, you’ll need to edit that single post template from tagdiv Cloud Library using the tagDiv Composer, like this -> https://i.imgur.com/UfGzZUU.jpg, click on single post author element and set in space box for example 5 -> https://i.imgur.com/3zeXf3Z.png after that save the changes and clear all cache the results should be like this -> https://i.imgur.com/Ij5y5nx.png
Hope this will help you!
Thanks that worked. I think what confused me is that if you select space = 1, it drops the whole row down, but more than 1 adds a space.
I’m glad that the problem was solved!
If you have other questions, just let us know!
