Problem with Slider Revolution Plugin
when I create a new slide I can’t change the “Desktop Image Width” from “Layer Grid Size”. I tried everything, but I can’t change the image width size. I mean I would like the slider image width to be smaller than default option, for example I would like it to be like 800X…, not as a default 1240X…
So, the problem is when I change the image width size and I save the setting, the image width is still 1240x…and I can’t change it!
Does somebody know what is the problem?
Maybe this will help: https://www.themepunch.com/faq/set-max-width-for-slider-5-0/
(please note that we are not the plugin authors so you will have to search through the plugin documentation for plugin specific settings.)
I hope this helps.
