the words aren’t on top of the image and it looks ugly. also if I want to use the big slider, how do I make it go over the sidebar and not be displaced by the sidebar.
upload a bigger sized (more better and big dimensions) image
You can also use the thumbnail upscale plugin I often recommend on the forum. 🙂
Well, you need to regenerate the thumbnails using the “regenerate thumbnails” plugin to make the new larger images to fit the slider. It will “from now on” make new images.
And, obviously, if you’re using a caching plugin of any kind, you need to turn OFF the caching before building new images so they are seen at new sizes.
As to other issues, you had the broken layout from the outset when I looked at it earlier; but at least your image is now filling the space.
Almost looks like you have been changing the spacing between columns or blocks.
But I’ll leave that for somebody from tech support to help you with.
simchris.
Please use this guide: https://forum.tagdiv.com/update-the-visual-composer-plugin-wpbakery/ and install the WPBakery Visual Composer plugin from the plugins folder that came with the theme files.
Then please disable all plugins and then regenerate thumbnails, also remember to empty cache.
If this dose not solve this issue please send your wp-admin user and pass at contact@tagdiv.com so we can check this, also send a link to this topic or specify your issues details.
I’ve worked out a couple issues, however there are still problems everywhere I go. When I use child categories it appears in the modules when I select featured but not when I select another category. Both have subcategories but they only appear on the modules when I select the featured (not features from the theme).
I’m nor sure I understand what issues you have, please provide more details about this, a screenshot would also help. I have checked your site and seems to work fine: http://screencast.com/t/uFagyknzlC
Please let me know!
