problem with social media plugin
facebook widget pulls the key but counter doesn’t work
  • This topic was modified 8 years by bear29.
The social counter should work if configured properly
https://forum.tagdiv.com/tagdiv-social-counter-tutorial-2/
Set it according to the guide, all fields must be filled with the necessary information. After doing this clear any caching installed.
If there are still issues please provide a link to your website where the counter is present, we will inspect it.
I have the same issue. The social counter does not work for Facebook.
@tarax69
Please provide a link to your website, leave the Facebook data configured in the social counter. We will inspect it.
I have the same problem. Don’t work with facebook :S
https://www.elchicharrodigital.com
@medialife
The website you mention seems to have problems at the moment
https://www.screencast.com/t/qEH29MfzQh
Check with your hosting provider, something must have happened. We will inspect the social counter after resolving the issue.
Hello guys,
It seems i have the same problem at http://www.dogforum.gr
Thanks a lot!
Please try and use only the numeric part of the Facebook Id
https://www.screencast.com/t/Hm0ItJP6y
Enter only those numbers in the Facebook ID field of the social counter, and check the results. It should display accurate information. Please let us know if there is still a problem.
Resolved!
