Problem with Speed Booster
My site is; frelsitv.com
I get this error in System Status;
Speed Booster v4.1 – Disabled – incompatible plugin detected: adrotate-pro/adrotate.php
I just upgraded Adrotate-pro 3.17.2.
Please help.
Open plugin editor and delate this section http://screencast.com/t/RZLIOPUNdqh
SpeedBooster has a function for plugin compatibility. If it detects any other plugin than the list specified it will shut down. Adrotate is apparently not on the plugin list. The method IngGeek showed will disable the plugin compatibility option so Speedbooster will work with all your plugins (Thanks IngGeek)
