I have added a cloud header template and set it as sticky. https://templatetester.com
However, the menu doesn’t work as sticky even though on the zone manager it is set to be sticky.
What could be the problem?
Hello !
Please make sure that your settings are set here: https://www.screencast.com/t/v8GFDNmOO Is this what you have set up ?
Hi Vlad,
I had those setting with the previous header and it was working fine. However, when I have set the custom header I have created from the cloud library, those menus disappeared.
Moreover, I have discovered 2 more issues. As I have uploaded the new header, on mobile the homepage doesn.t show anymore. Plus, if you check the home page, you will see the at the top left of the screen there is a writing “page contents’ that I don’t know where is it from.
Hello !
The page contents was there when I first checked too.
Let me take a look at your setting and see what’s going on there, please contact us via email at contact@tagdiv.com and provide admin login. Include a link to this topic in the email.
