Problem with sticky menu "more" button
Hello since the last theme update (tonight) i have several problem with the sticky menu and the command line “Drop menu items in More”, well sometimes it work when i reload a page and sometimes it not works (frustrating) . I i go to the builder everything seems just fine, but when i reload EVERY SINGLE PAGE sometimes (most of the times) i see all menu voices. Here the link: https://www.lindipendente.online
The right menu is the one the when scrolled down have just the logo on the left and menu voices on the right.
I’ve using Litespeed cache, but i’ve purged many times with no success. Firefox seems to be less sensitive to the problem, while chrome and safari aren’t.
I just verified and the menu works well https://i.imgur.com/t3zdWXh.jpg -> https://i.imgur.com/oFsrao3.png
it’s the sticky. when you scroll down…
So, do you want to have more also, on sticky? If yes, then please edit the menu that is on the sticky header.
Serious? Was edited and enable, Now i turn off the sticky menu cause it’s ugly, but there is a problem with your latest update. Bye
I make a roll back to previous version and it’s ok
For more works for the latest version of the theme https://i.imgur.com/OIy7Wfc.png
NO WAY. THE LATEST VERSION OF NEWSPAPER GOT A BUG on the sticky menu mode, the bug disappear if you roll back to previous theme release. that’s it.
Hello SamRe
I can confirm that the sticy menu doesn’t work for me either since last version of theme…
Yep, i open another thread about this bug, because the conversation here was kind of surreal.
Btw, wanna talk about advertising about web design services on PAYED VERSION of newspaper? Imagine if your customer click there and then fire you! FUNNY. 😀
well…
When I go to your website, the sticky menu seems to work fine…
https://ibb.co/7XvXb7h
yes as i wrote before, i did a roll back to previous version of newspaper…
ok ok… good move ! Is it easy to do the rollback ?
and which version did you go back to ? 12.2 ?
  • This reply was modified 3 years by byothe.
in theme menu tag div got a kind of time machine mode, quite easy.https://ibb.co/bb38YtQ , yes 12.2
  • This reply was modified 3 years by SamRe.
ok thanks
I just did the rollback to 12.2 and now sticky menu works like a charm…
The option to turn them off (the ads )can be found in Newspaper -> System status -> https://i.imgur.com/N5Iq4j6.png
I did a lot of tests, and for me and my colleague’s work, but maybe you have some plugins, or a strong cache. Purge the cache a few times.
Viewing 17 posts - 1 through 17 (of 17 total)
