Problem with Sticky
Hi everyone, I have a problem with a Demo, specifically with the Gossip demo. The Row is divided into 3 columns and 2 of these columns are in Sticky, but at some point one the right column overlaps with the next column. How can I handle this problem? Thanks
Hello !
Please provide a link to your website in order to take a look. Let us know where this is happening.
Hi Vlad, my site is http://www.vadoanapoli.it you can see on the right the B&B and Recipes sign joining as soon as you scroll down the site, also it takes time to load the menu bar. When it finishes loading, the problem I told you about happens.Thank you for your precious help.
Hello !
You will have to first start looking for a plugin conflict. please deactivate ALL plugins except tagDiv ones, also if you are using child theme or cache plugin, deactivate them, clear all cache and try again.
Also you can try and remove and re-install the tagDiv Composer plugin.
Let us know the results.
Hi Vlad, I tried but to deactivate the plugins, but it doesn’t work. The menu bar loads something, but I don’t know what, can you check? Thanks for your time
Hello !
Something worked, I have just inspected your website and now everything works perfect.
Can you please confirm.
Vald the problem I solved by simply removing the stikly from the middle column. It wasn’t the solution I wanted, but I can accept it. But the problem of the menu remains, it loads for too long I can’t understand what the problem is, you could give it a check. http://www.vadoanapoli.it you will see that as soon as you enter the menu bar it loads those two lines for a long time. Thanks
Hello !
That happens because you have 1 image that is not working as it should from what you can see here: https://www.screencast.com/t/5eyzFF1z05Ef You need to remove that image because that is the issue that occurs at the moment.
Thanks Vlad, the problem is that, but I looked in the Cpanel, in the WordPress Media, and tried to preview the photo, but I can’t and I don’t know where to look for the 7.jpg photo. How can I locate it to delete it? Thanks for your precious help
Hello !
If you don’t remember where the file has been inserted you will have to look in your media library there, you should be able to see where the file comes from. After you find the spot, remove it from cpanel.
Hello !
Vlad, I can’t find this file anywhere. For a few months I have changed servers, there may be some files lost, but I would like to know where to look for this photo to delete it.
https://192.168.0.120/wp_011_test/wp-content/uploads/2018/03/7.jpg
I went to Cpanel but this folder doesn’t exist wp_011_test I don’t know how to do it? how can i locate the page and delete this search?
Hello !
Unfortunately with this we cannot help, What I can tell is that most likely this was used from a localhost: https://www.screencast.com/t/sgEtHgs22X as you can see here the start of the url is most likely a xampp path, localhost.
