problem with style 6, 7 and 8 in mobile (arabic version)
i’m trying to editing style.css file to be fully arabic version, almost done but i have problem with featured photo in style 6,7,8
http://www.techlic.com/2016/02/04/220/
Hello sherby,
I have checked your website and I have not seen errors and everything seems to work as expected. Also, I notice that you are using RTL method. Unfortunately, our theme has not been designed to use with this kind of method and it is possible to appear some errors wich need some additional customizations.
If is not what you mean, please provide more details about your problem. Also, you should provide some screenshots with this issue for a good understanding.
Thank you for the message!
well, i’m aware of that totally, and i did some work on it, but as the link i sent, i have problem with featured image in those styles in Mobile site, it seems to be error, and i did restore this code part and it’s still not working.. so if there any missing code i hope you can provide it to me
regards,
here’s screenshot
Hello sherby,
Unfortunately, this kind of issue come from your RTL. As I said you above, our theme has not been designed to use this kind of language support but only LTR, sorry. I have tested on my side and I can recreate this issue with some Arabic language…try to disable your RTL and see that this problem disappear. If you want to adjust our theme with this kind of language support, please consider hiring a freelancer/developer to implement this functionality for you in our theme because it is not a simple task and requires custom work and we cannot provide custom services at the moment, sorry!
