problem with sub-categories, Help!
hi!
my parent category named VIJESTI and (now) my sub-categories are arranged 1. BiH 2. Mostar 3. Svijet but i wont to be 1. Mostar 2. BiH 3. Svijet. How i can do that? it seems to me that are sub-categories arranged by alphabet
Do you want to change the order of subcategories from the Mega Menu? you can doit by adding an order or orderby parameter on here – http://screencast.com/t/NwYj18KrJ
Check the function reference and the parameter options here – http://codex.wordpress.org/Function_Reference/get_categories
Thank you, Emil G.
i will try
thanks
