Hello. I have problem with sub-menu in woocommerce from your theme. When i put menu in sidebar in shop, all sub-menu items become main menu items. There are no drop-down like in main menu in header zone.
Test version on test server here: http://test.vkyrse.info/shop/
As you see, sub-menu items looks like:
Main menu
– Sub-menu.
I want that it looks like main menu (about sub-menu items).
It seems you are using a standard menu widget of WordPress. Tat will not work with a dropdown as you expect it to. It will only show as a list, and not a standard menu. You will have to use a plugin if you want to have a drop-down menu in the sidebar as our theme has no such options.
Sorry for the inconvenience.
I think problem that theme does not have a “shop area menu”, like top, main and footer areas (not full support woocommerce, how do you think)?
Can you add this feature in the next update?
I don’t found any plugin that works as i want for this đ
Or maybe i can insert menu area with some shortcode or code of php in widget?
This reply was modified 9 years by
kiev_walking.
I’m not sure what a shop menu is supposed to be like. In the woocommerce official docs this is presented as a simple wordpress menu: https://docs.woocommerce.com/document/docs-menus/
You can then use a custom menu element in visual composer: https://www.screencast.com/t/6SaCvAMv
Please contact us via email at contact@tagiv.com and provide a link to your site and wp-admin so we can login and investigate. Please also post specific instructions to exactly what you are trying to achive and how you tried it and did not work.
