I’m using your mega menu in my menu. The one menu when it opens shows the thumbnails of each post with the sub category labelled in the corner of each. Another menu does the same but it only shows the main category label, not the sub category. How can I change it to show the sub category. See below:
This is correctly showing the sub category:
This is incorrectly showing the main category:
If the posts are assigned to more categories, then will be display the first category in alphabetical order, if you want to be display on the posts a specific category, then you need to set that category as primary category for that posts.
In this example -> https://i.ibb.co/G5Kh43h/Sub-categories-names-NOT-showing.jpg you have set a category with 3 subcategories and the thumbs show different categories because the posts are assigned t more categories and “Afrikanns” is the first alphabetical category, if you click on one of that posts you’ll see that one of the subcategories from the mega menu is assigned to that post.
Hope this will help you!
