Problem with Table of Contents module
Your Table of Contents module is not compatible with the RankMath SEO plugin. Can you add a filter to the module that will make the module recognizable by this famous SEO plugin?
The instructions are here:
https://rankmath.com/kb/filters-hooks-api-developer/#add-toc-plugin
What do you mean by that? Is making parts of your theme compliant with SEO standards something extra? Will you be implementing this solution or should you consider changing the theme?
The theme is compatible with the Yoast Seo plugin.
I know that the theme is compatible with the Yoast Seo plugin. The question was whether you would ensure compatibility with e.g. RankMath or whether the user was forced to use Yoast Seo.
There are some implementations that are compatible, but not for all options. If you want compatibility please custom work team https://tagdiv.com/submit-a-request/
The topic ‘Problem with Table of Contents module’ is closed to new replies.
