Problem with tables?
I recently posted a post with tables on it. When viewing it on mobile, the table over extends to the view of the post making the rest of the table unreadable.
Can you guys put something like those in Wikipedia? It automatically adds scroll bars on mobile view of its site.
hi,
how did you add the tables, we don’t have tables in our theme.
I think maybe you can use some css to add a scroll bar. this is a maybe.
Thanks for you message.
Radu A.
Hi Radu
I just copy and pasted a table. I think this should be a must for responsive themes. Kindly check some tables in Wikipedia.
You can try with a table plugin, to see if this is responsive http://wordpress.org/plugins/easy-table/
