Problem with taboola and pagination
Hi guys!
I have a problem with taboola ads and I hope you can give me some help.
When I choose the option to show the ads below the article, it shows the ads below the article but above the pagination, wich is terrible because it breaks the pageviews ratio.
Is there any way to make the taboola ads widget appear only below the pagination on each page?
In can see the problem for yourselves on any article from my website, like this one, for example: http://www.vortexmag.net/lusitanos-a-tribo-que-os-romanos-demoraram-200-anos-a-dominar/
thank you so much for your help and keep up the good work!
Fernando
I’ve checked your link and it seems that it has an unclosed tag or something. Unfortunately there are scripts on the site that prevent right clicking and this is making the debug process very hard.
The ad can be moved after pagination only if you edit this file: http://screencast.com/t/4UQ6mGyGTQa
the loop file can be loaded from a child theme fore convenience. Also please make sure the you are editing the appropriate loop (each single template has it’s own loop).
Radu O/
Hi Radu!
Problem solved thanks to your precious help! You guys are amazing! Thank you so much!
Fernando
