I have recently installed Newspaper7 on http://www.burgundygirl.com and am having an issue with a tabs section with Big Grid 5.
I currently have 4 tabs created on the homepage and want each to show posts from 1 single category. How do I link the tabs to a Big Grid 5 with 1 category showing?
I have checked your site and saw that you have a js error in your console. Your tabs are not working currently. It’s probably a plugin conflict so try to disable all plugins except visual composer, clear cache and reset cdn files if you use it.
FOr the tab setup, you only need to create a tab element with 5 sections and add a big grid 5 to each section, then for each big grid, you need to specify a separate category from block settings. Please read this guide to learn how to filter posts inside blocks: https://forum.tagdiv.com/block-settings-guide/
Thanks but what do I set under Section Settings > Section ID? What ID’s do I use here?
I have disabled all plugins and still it doesn’t work so it must be a different issue…
This is the error I got:
jquery.js?ver=1.12.4:2
Uncaught Error: Syntax error, unrecognized expression: #
(admin edit: please use pastebin for long strings of code)
I can create login details for you so that you can check
This reply was modified 9 years by
Bogdan B..
Please remove any js minification or optimization you may have on your site. That is the cause of the issue. Something is breaking the theme js. Please also check your cdn server if you use it and remove any js optimization options. If you do not know of any js optimization or minification please contact us via email at contact@tagdiv.com and provide wp-admin so we can login and investigate.
Please also include a link to this topic so we can identify you.
