Problem with tabs.
Hello. I have installed a prebuilt demo. On the front page I have a tabbed content with lastest and recomanded articles.
I want to change those 2 things with 2 shortcode. I have created a new tabbed content but it force me to choose pages. i want to 3 tabs there.
How I cand put custom tabs, as I want?
The tabbed content will use for each tab a page, so what you need to do is to create a page for each tab and set the shortcodes you want i those pages, after that set the pages ids in the tabbed element.
How to Use the Tabbed Content shortcode – https://forum.tagdiv.com/use-tabbed-content-shortcode/
Hello.
I have another problem. I have installed a new theme prebuilted. When I am saving home page without making any changes I am receving this message.
Invalid data Current state has involved an issue. You could try an UNDO operation (CTRL+Z / CTRL+SHIFT+Z). Why this is happening?
I have reinstalled the theme from 0 and now it is ok.
I have a custom shortcode, made by me. How I can insert on the pages , where I want? This time it is not in the Tabbed content. I want somewhere on the page to briong something random from the database. Tks.
I want to put a slider revolution shortcode….
For the slider revolution shortcode you can use the tagDiv Composer and the rev solider element – https://i.imgur.com/fIjPrLn.png
Also, you can set shortcode with tagDiv Composer, you set it in a column text or text with title element in code/text zone – https://imgur.com/DSSni9j
I need to create a section on my homepage that looks exactly like the “DON’T MISS” section in this picture, but I want to insert my own shortcode inside it.
How can I create a section that matches the site’s style but contains my custom code?
All the preformatted “Big Flex” or “Flex Block” sections already have fixed content and I can’t modify them.
One Article
Now I am receving an error again.
Errors at columns elements: 8(models) : 9(dom). The model does not match the content Current state has involved an issue. You could try an UNDO operation (CTRL+Z / CTRL+SHIFT+Z)
How can I identify the error? I can’t edit the home page anymore, it is in read mode only.
If I am making a zone that I like, can I save it for later, like u have save all the flex box, etc?
  • This reply was modified 1 year by Delicatu.
If you have a shortcode and you want to make it to look the same as our blocks, then you’ll need a developer and designer. But what do you want to display? Our blocks can display articles, pages, CPTS, so maybe it is no need to use a custom shortcode.
If the problem appeared after the shortcode has been set on the page, the the problem is related to it and it can be resolved only by removing that shortcode, usually this can be done using a page revision https://www.wpbeginner.com/beginners-guide/complete-guide-to-wordpress-post-revisions/
You can save elements in tagDiv Composer by using the right clock on them and save as element – https://i.imgur.com/pTRr9Hm.png
Hello.
Each post will have a “Custom Post,” as shown in the image below. I want to be able to add these when creating a new post, not manually. Also, in the custom post, I need to have links on certain words. I can’t find anything like this by default in templates. How can I make them appear automatically, like they do with the Custom Post Types plugin? Or I have to install that plugins and then use in the Custom Field frothe theme?
Ok. I have installed ACF. I have cerated 2 ACF ‘s.
They appeared in the post area. I added values for the two fields, I added them as custom fields on the page, but they are not displaying!!!!!
I managed to get it working with those ACF fields. But I have an Inner Column added and I can’t delete it from the Single Page layout. How can I remove this element?
I’m glad that in the end you manage to resolve it! 😀
The inner column is part of the inner row, if you want to delete it you can delete the inner row (the inner column represent the columns of the row, one by default and can be set up to 4 inner columns).
Hello.
I have created a custom post type. I want to create a template for it. Is there any way to copy and paste from the Single Template defined in WordPress Templates – Single Templates? I want to create a custom page, but have it look like a post page. When I want to edit a single-event type page, the TagDiv Composer does not appear, only the simple editor.
Thank You!
Hello again!
Is there any way to display Posts (not just Pages) inside Tabbed Content? Can I create a custom Tabbed content to use Post?
You can create a cloud template for the CPT using this section https://i.imgur.com/RsR7JhE.png but it will be need to import a pre-made template and edit it or start from 0. Unfortunately if you copy the single post template to cpt template will not work because are different elements.
The Tabbed Content can be used with pages – https://forum.tagdiv.com/use-tabbed-content-shortcode/
Ok. But in CPT are onle 13 templates, verry simple.
I need My CPT toi look exactly like posts. There is no way to duplicate? Because to create from 0 is so nasty.
Thank You!
Unfortunately the only way is to create it from scratch, sorry!
Hello.
How can I change the total width of the site? I want to make the site a bit wider. Is there an option in the Theme Panel?
Thank You!
To set a page to full width (or a cloud template), you’ll need to edit it with tagDiv Composer like this -> https://i.imgur.com/i5IUJ9E.jpg add or select a row and stretch it after your needs -> https://i.imgur.com/WKYebPX.jpg -> https://i.imgur.com/TO1BZ3M.png -> https://i.imgur.com/Yq8UCv3.jpg
If you want to make the layout full width, then to change the website width, you need to make sure that you don’t have set a background color/image in the Theme Panel because this makes your website boxed. Make sure this option is disabled => https://www.screencast.com/t/ejiNPCBF
Hello. Today my site is “Briefly unavailable for scheduled maintenance. Check back in a minute.”
In error log I have:
Date: Wed, 01 Oct 2025 06:19:24 GMT
Content-Type: text/html; charset=UTF-8
Transfer-Encoding: chunked
Connection: close
Content-Encoding: br
X-Powered-By: PHP/8.0.20
Access-Control-Allow-Origin: *
Access-Control-Allow-Methods: POST,GET,OPTIONS
Access-Control-Allow-Headers: Origin, X-Requested-With, Content-Type, Accept
cf-cache-status: DYNAMIC
Report-To: {“endpoints”:[{“url”:”https:\/\/a.nel.cloudflare.com\/report\/v4?s=JUDOWwoNEqE9jB6as43O3yqW6RNSPJBjUvL1D2dNFQG4yOm2pNl9BOX9ch4hoU%2B3ivhiwyTR9kqOA2HguObN%2BxX8f%2Fj%2FElk6HpNvvg0szh4CnT4wwCmn8EY3bihJLwEzk9U%3D”}],”group”:”cf-nel”,”max_age”:604800}
NEL: {“success_fraction”:0,”report_to”:”cf-nel”,”max_age”:604800}
Server: cloudflare
CF-RAY: 9879d924ec180533-OTP
server-timing: cfL4;desc=”?proto=TCP&rtt=1275&min_rtt=1272&rtt_var=483&sent=4&recv=6&lost=0&retrans=0&sent_bytes=2836&recv_bytes=989&delivery_rate=2229407&cwnd=252&unsent_bytes=0&cid=8c11637ce6c3dd9d&ts=532&x=0″
“api_reply”: {
“key_is_valid”: true,
“key_status”: “active_key”
“debug”: {
“sql”: [
“query”: “SELECT * FROM ip_tagdiv WHERE IP = ‘86.107.43.36’ LIMIT 1”,
“run_time”: 5.888938903808594e-5
[status_code] => 200
[protocol_version] => 1.1
[success] => 1
[redirects] => 0
[url] => https://cloud.tagdiv.com/api/templates/check
[history] => Array
[cookies] => WpOrg\Requests\Cookie\Jar Object
[cookies:protected] => Array
[filename:protected] =>
Why does this error occur, and how can I fix it? Thanks!
Hello. I have solved the problem.
Viewing 22 posts - 1 through 22 (of 22 total)
