Problem with Tag Div Composer Not Functioning with Error Coming Up
Hi:
I just put in the latest version on Newspaper on my website. The theme updated properly and the website looks good. However the Tag Div Composer does not work, an error appears in red:
” Errors at columns elements: 1 (models) :dom. The model does not match the content. Current state has involved an issue”
I also installed the Enable jQuery plugin you recommended and am still having issues.
I do not have the latest WP Baker plugin updated. Could this be causing the issue as well?
Can you please also tell me where to update the Footer info? I need to make changes and it is not coming up anywhere. I have searched the entire website.
Please help,
Thanks,
Maureen
Hi: I was able to fix the Footer issue, I found the Footer page and the Tag Div Composer worked on this page. I could not get it to open the Home page, so I’m still having problems here.
I deleted the Enable jQuery plugin as it said it was for old content and not needed with the new plugins.
Maureen
I really need to update the Home page, and get the issue resolved. If you go to the page and go to More Developer Tools the error comes up.
Hope you can help,
Maureen
It actually worked on the Home page earlier tonight, as I uploaded some new ads.
I did update the plugins. Then it stopped working.
I then uploaded the updated Newsletter Theme and plugins, no problem and I thought this would fix it, but still no luck!
Hope you can help,
Maureen
Hello !
We will need to take a look and see what is going on there. Please contact us via email at contact@tagdiv.com and provide the following:
– admin url and credentials
