i build home page with elementor and i create column and 4 button in one column but after i public automatically show 8 button
so i deactivate plugin line by line i found when i deactivate tagdiv composer website work fine than i activate td composer found same problem
when i publish a page problem found
Unfortunately, the Elementor plugin has not been tested with our theme and therefore, we cannot say for sure if it will work or not as expected with the theme, sorry! Also, we cannot provide support for untested plugins.
This is our list with tested plugins with our theme -> https://www.screencast.com/t/cmPkh9jba4sZ
I want to this type homepage – https://www.screencast.com/t/Nupmg2a9t58g
how to create this type homepage please tell us
You can build this page using tagDiv Composer you need to make a new page and set in the row some inner rows than set the layout on them as in your example https://i.imgur.com/ixRUEVS.png -> https://i.imgur.com/yxLmd3f.png after you set the containers for the layout you want -> https://i.imgur.com/UEVUKvM.png you can set the element you need inside the empty inner column, for example if these https://i.imgur.com/npncE57.png are posts then you can use some flex blocks to display them -> https://i.imgur.com/98dxDsg.png -> https://i.imgur.com/yFPPIXc.png -> https://i.imgur.com/vSAsieZ.png -> https://i.imgur.com/q2DYJrg.png also there are other element in tagDiv Composer that you can use.
Hope this will help you!
