Problem with tagdiv composer loading
hi
my hosting say
There appears to be a javascript issue of the builder, which is why it’s not loading:
Code:
js_files_for_wrapper.min.js?ver=__td_aurora_deploy_version__:434 Uncaught TypeError: Cannot read property ‘shortcode’ of undefined
at js_files_for_wrapper.min.js?ver=__td_aurora_deploy_version__:434
at Function.m.each.m.forEach (underscore.min.js?ver=1.8.3:5)
at Object.updateSavedShortcodes (js_files_for_wrapper.min.js?ver=__td_aurora_deploy_version__:433)
at Object.init (js_files_for_wrapper.min.js?ver=__td_aurora_deploy_version__:411)
at js_files_for_wrapper.min.js?ver=__td_aurora_deploy_version__:436
(anonymous) @ js_files_for_wrapper.min.js?ver=__td_aurora_deploy_version__:434
m.each.m.forEach @ underscore.min.js?ver=1.8.3:5
updateSavedShortcodes @ js_files_for_wrapper.min.js?ver=__td_aurora_deploy_version__:433
init @ js_files_for_wrapper.min.js?ver=__td_aurora_deploy_version__:411
(anonymous) @ js_files_for_wrapper.min.js?ver=__td_aurora_deploy_version__:436
vc.js?ver=5.4.5:1 Uncaught ReferenceError: vc is not defined
at vc.js?ver=5.4.5:1
It could be the same issue mentioned in this topic
– https://forum.tagdiv.com/topic/javascript-error-td-composer-wont-load/
You could ask your hosting if the concatenate scripts is set to true. Let us know.
