When I try to work with the constructor it keeps loading continuously when I add some element. This is a video: https://www.loom.com/share/f574dbe2c15e4e00ad7e4cfce2428d3c
I have deactivated all the plugins in case there was incompatibility, I have changed from the child theme to the main one, I have tried with different versions of PHP (7.2, 7.3, 7.4) from the server, I have tried the theme that I installed itself with different versions and it has not It worked, I have updated the wordpress to the latest version and it has not worked. I have all the plugins and the theme in the latest version, the updated wordpress. I have a dedicated server with good capacity.
The site: https://autopos.es/
1. disable TagDiv Composer
4. install TagDiv Composer
5. activate TagDiv Composer
If this won’t help, then we need to take a look and see what happened there.
– admin url and credentials
Our team will take a look!
