Problem with TagDiv Editor
I can’t use the TagDiv Composer, and nothing shows on my website as you can see at ghostscbsfans.com (only lines of code).
I tried to change the header template and use another one, but it’s the same. I tried to deactivate the plugins, not working.
Every pages, every posts or anything it says “Error at zones: 6(models) : 1(dom). The model does not match the content Current state has involved an issue. You could try an UNDO operation (CTRL+Z / CTRL+SHIFT+Z)”
Thank you in advance
I finally managed to resolve the issue: I have re-installed the latest version. Hope it can help someone else!
I’m glad that you managed and solved the problem.
Have a great day!
